Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Maximum slenderness limit AS4100 1998
2 REPLIES 2
882 Views, 2 Replies
Hi, I've been encountering the instability warning in the steel design calculations (AS 4100-1998). I cannot seem to find the clause on this slenderness limit ratio in AS 4100 1998, so I wondering how these two limits of Compression: 200 and Tension: 300 are obtained from?
William
2 REPLIES 2
I can't say for 100% sure, but I have heard a rumour that it was added to Robot for another (Canadian) code, then left in for the AU code as the developers couldn't find a slenderness limit in AS4100.
Not really sure if this is true though.
Tony
Artur.Kosakowski
Tony is right. It is based on the analogy to other steel design codes :-).
Artur Kosakowski
