Hello
Does robot structural analysis solve for maximum permissible loading.
for example if i have an HEA 200 beam of length 6 m can robot solve for the maximum point load it can support at the middle
regards
Solved by Rafacascudo. Go to Solution.
Solved by Artur.Kosakowski. Go to Solution.
You can run verification of such beam according to the selected design code and increase the force till the safety ratio is 1.0.
You may find the recording of the 3rd Robot webinar on steel design helpful. It is accessible from:
Rafael Medeiros
