Material data in the report
EnricoCorvaglia
Message 1 of 8
EnricoCorvaglia
Good morning to all
I modeled a rinforced steel tank and i used shape s 355 to rinforce it (and i see s355 in the beam data too). when i export material data in the report I see this (see attached image).
Someone can help me?
thanks
Replies (7)
Message 2 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @EnricoCorvaglia
Having a picture alone it is a bit hard but if you could you attach the model than I will try Smiley Happy
Artur Kosakowski
Message 3 of 8
EnricoCorvaglia
the problem is that Robot show alway generic steel although i put S 275 for all bars and in project preference.
This happen for all model i make.
I attach the model (i'm beginner with robot so if you note other wrong things please underline them )
Thank you so much.
Message 4 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @EnricoCorvaglia
Which table are you looking at?
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 5 of 8
EnricoCorvaglia
Good morning
the attached table
thanks
Message 6 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @EnricoCorvaglia
Try to open the file in the repair mode following the steps from this article.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
Message 7 of 8
EnricoCorvaglia
Hi Kosakowski
thank you for answer
I opened the file in rapair mode, but i obtain the same result.
I need a all materials caratteristic summary to put at the biggining of Calculation Note.
Italo
Message 8 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI @EnricoCorvaglia
Try the attached file.
Artur Kosakowski
