I took a look to your model :
1)
-> see the modal shapes : acutally the modes are only local modes, I think this is due to the fact that your roof is light and your bracinf is quite stiff (St andrew crosses), in the other hand, your columns are quite high.
that's why the local modes appears before the global ones. To illustrate this you can try two things : just to see, try to change the thickness of your roof into something heavy (for example EP30 which is concrete 30cm), or remove the crosses and put fixed support at the bottom; In both case, you will find that 5 modes will give you more than 80% of the mass.
2)
I the model I also remove the rigid links because I think it is double role with the fact you define a soft diaphragm.
Either there is no diapgram and you define Rlinks manually - Either diaphram but no Rlinks ? Am I right Rafal?
Rafal, this lead to a question about the local modes :
Is it possible toinactivate some element only for the modal/seismic analysis? I don't think so but ....
If not, the typical solution to solve the issue is :
- use concentrated matrix without rotation
- use fake material (very low density (0 is not possible but maybe 0.01 kN/m3) )
- Other tricks?
TS
