Map Scale Problem
Map Scale Problem
Map Scale Problem
Hello, I would like to ask if there is a way to change the highlighted "User limits" in Maps.
For example, I would like to select all mesh with Mxx smaller than 96kNm/m. I cannot get exactly 100kNm/m by changing "Division" and I cannot change the User limits Max. and Min., they are always 173.888 & -572.828.
EduardoMeruvia
Hi @Anonymous ,
You can change the user limits, by following the process below;
  1. Choose the limits you are looking for e.g. Max. 100kN/m & Min. -100kN/m
  2. on the [Scale Type Selection] drop down menu, select the option "User Define"
  3. Click [Apply] for changes to come across
If you follow the above method, you use be able to have any custom User Range Maps as desired.
Hope it helps!
Thank you😀
