Losing building attributes such as walls
After loading a  RSA2013 project in RSA2012 I have  problems with losing building attributes such as walls
(for RSA2013 this is corrected in SP1).
For new projects in RSA2012  I have the same problem.
 Who has a solution?
Rafal.Gaweda
Autodesk Support
Autodesk Support
Unfortunatelly we do not keep backwards compatibility reading robot files.
So in most cases it is either not possible to open file created in newer version in older one or some information may be lost in older version comparing to newer one.
Rafal Gaweda
The real problem is that I can't make new projects in RSA2012
See attached file this is as RSA2012 project (zip-file)
It seems that a config file is damaged.
Rafal.Gaweda
Autodesk Support
Autodesk Support
I do not get.
Start Building Structure type model or Shell.
Maybe by mistake you have turned on ACIS modeling. Turn it off.
If it is not the case, please let me know.
(you can always clear  cfgusr folder before next robot start)
Rafal Gaweda
Thanks.
Clearing then cfgusr folder before next robot start, has solved then problem
