load transfer probleme
dalhoumi400
dalhoumi400
   I don't know why, but the loads are not transferring to the beams. Thank you
the link to the model:
https://mega.nz/file/cy1nSQJb#nr2O3MC8byagfcPJfjhxWOkejU7ZPmBveov_t5EwCko
comressed link :
https://mega.nz/file/gusWgIgR#_rURunWWMls7QrBx5C0YpIBkLh7LcFg4oxvO8jnLgEE
Thank you
Accepted solutions (3)
JohanDuPlessis
@dalhoumi400 why do you say the loads are not transferring?
From what I can see, all seven beams are resisting load.
dalhoumi400
  • When I do Steel dimensions it give a wrong results number 90 as exemple
JohanDuPlessis
Member 90 is a concrete beam...
dalhoumi400
Thank you all, I found the problem. Indeed, there is a wall that is calculated in finite element mode under the beam which takes the loads.
