Load not applied to any object
prageeth_samarasingha
Message 1 of 10
I have to apply some point loads on slab, in model it was applied as a load on point but below warnings are appear as "Point load (#load number) not applies to any object in load case number xx"
any way to correct this or can this warning be ignored ?
Replies (9)
Message 2 of 10
Simau
Hi @prageeth_samarasingha
It depends on what panel calculation model you use for your slabs.
To apply Nodal loads you must tick "finite element" in calculation model parameter
M. Agayr
Message 3 of 10
These are point loads which are live loads to the structures on roof slab, directly applied to the cladding, thicknesses are not defined. I am not sure whether with these warnings has these loads are taken in to the calculation or not? if so what will be the solution, sucked here thank you for your assistance
Message 4 of 10
Simau
what is the roof material?
M. Agayr
Message 5 of 10
it is concrete since it is composite slab, this was not defined here,applied all loads to the cladding
Message 6 of 10
Here is the model ,could you please look at if possible
Message 7 of 10
Simau
No model attached
Please zip the file before sharing.
M. Agayr
Message 8 of 10
Model Zip
Message 9 of 10
Simau
Cladding don't have any thickness, so selfweight will not be taken into account.
Modifications i made:
- Replace horizontal cladding by a dummy concrete panel which thickness give 4 kN/m².
- Replace vertical cladding by 20cm thickness wall
- Delete DL2 slab case.
You have to do:
- Reintroduce Nodal loads (LL2 Ducting)
- Replace wall 20 panel by your wall.
- Remesh all panels
Model not meshed attached
M. Agayr
Message 10 of 10
thank you very much Simau, really appreciate
