Load/Moments at cheracteristic point in Tabular Format
Is it possible to extract Loads/Moments at characteristic points of elements in tabular format inside Autodesk Robot.
mustafahesenow
Hi @Anonymous
Yes you can.
Select the member then right click then table Choose table filtered to current selection then press ok
The forces table will appear for you to add another point where you want to view the forces right click then table column then go to division points tab then choose characteristic point Input X location then click add then click ok
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Rafacascudo
Additionally , to extract results on max/min charateristic points , just click on "refresh" button on the same window , and it will list on max/min points for all involved forces of the bar in question
Rafael Medeiros
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I just wanted to ask if you managed to display the required results? If yes, would you mind marking the corresponding post as the solution so that it is easier to find by others? Thank you.
Artur Kosakowski
