Load in the beam as for column
Hi! Am trying to understand amount of load and moment entering in the beam after analysis as for column, would you help me knowing the dead and live
load in the beam after analysis so i can compare with manual way?
Find my attached video
mustafahesenow
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Hi, i´m having what i think is a similar issue.
A simple example: a beam supporting a slab receives a load from it. ¿Is there a way to see the load diagram that the slab causes on the beam?.
Thanks!
