Load Definition - kN/m2? Possible?
Hi all,
I was just about to apply loads to a structure I modeled. It's a high rise building in concrete and steel, so only basic surface loads and wind loads. I discovered that loads are defined as kN/mm^2.
I've always worked with kN/m^2 and would prefer this setting.
How can I change this? I tried manipulating Job Preferences, but no luck. I even started a new project to see if that helped, but I can't seem to pull it off.
Hopefully this can be done and hopefully it can be done without starting the job all over, since it's been a lot of work.
PS: Structure dimensions were set in mm.
Thanks in advance!
ducvanvt
It should be possible. Have you tried Job Preferences->Units and Formats->Forces->Stress->Select Area unit as m2 ?
Thanks!
I believe I have. But I tried it once more now, "Save current parameters as default" and "Close", but I still have kN/mm^2 for the loads.
Either something else needs to be done or I'm doing something wrong or it is because those changes can't be made after a job has started? Or maybe because I use "mm" for structure and section dimensions?
ducvanvt
yeah you should change structure dimension to m
