Load Combinations in printout
I'm trying to insert load combinations (via screen shot) in printout but nothing shows up?
Capture.PNGWhat can i do to make it display properly?
Regards!
Rafacascudo
did you try "combinations table" ?
Rafael Medeiros
Hi @Rafacascudo
I screen captured this table,....the result is on my first post,....
Capture.PNGWhat other "combination table" exists?
Regards!
Rafacascudo
it´s working here
comb table.jpgtry setting it to "landscape" or adjusting the table columms
Rafael Medeiros
Thanks @Rafacascudo for your suggestions!
I just unchecked "adjust....." and miraculously combinations showed up!
Capture.PNGDo you, perhaps have a tip for this issue:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/table-of-contents/td-p/7984383
I'm wasting a lot of time for trivial things... 😞
Regards!
