Load combinations for foundations
siyak.sharifi
siyak.sharifi
I need to define manual load combinations, not those generated by software. But I am not able to find anywhere to define custom load combinations, Please advise.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @siyak.sharifi
Define loads and manual combinations in model space. Use simply supported column model.
Robot Structural Analysis 2024 Help | Generate Manual Combinations | Autodesk
Such combinations can be exported to foundation design module.
Refer to https://www.youtube.com/watch?v=Pe8N_gCMA94&list=PLY-ggSrSwbZqow_60fiqJwS69mg1nQMzk&index=4
Krzysztof Wasik
siyak.sharifi
Perfect thanks, it worked. I was trying to define combos inside the foundation environment which I could not. Your answer was really helpful. Thanks.
