Link between finite elements and panels
I would like to know how I can set the link between a finite element and a panel using VBA for Excel.
I mean:
I have created a finite element on an existing rectangular panel (the nodes are coincident) -> I'd like to set that the finite element I have just created belongs to the specified panel so that it can have the same properties like thickness, loads and so on.
Is there a possibility without creating a new panel on the selected finite element (because in this way I will lose loads applied on the panel)?
Thank you in advance!
Rafal.Gaweda
Autodesk Support
Autodesk Support
I do not see any way without creating panel
This may help a little:
http://forums.autodesk.com/t5/robot-structural-analysis/get-local-axis-of-finite-elements-via-api/m-...
Rafal Gaweda
