Announcements
LINK as in SAP
HectorDuenas
LINK as in SAP
HectorDuenas
Does exist in Robot the possibility to create an object similar to the LINK nodes (with the same or different coordinates) as used in SAP 2000?
Rafacascudo
What does the "link" feature do on SAP?
Rafael Medeiros
HectorDuenas
It connects two nodes, that could or not have the same coordinates, and the two nodes are related with some kind of law, linear or nolinear.
In a similar way as the "compatible nodes" in Robot, but without the requirement of havng to be the extreme of an existing bar.  That means the two nodes exist independently of a bar.  They just require that one of them should be a support.
Pawel.Pulak
Autodesk Support
Autodesk Support
As concerns 2 nodes with the same coordinates LINK in SAP is very similar to Compatible Nodes in Robot.
Compatible nodes in Robot are dedicated mainly to bars (at least the interface and displayed hints suggest it) but is is also possible to assign them:
1/ between bars and nodes of panels - see for instance the continuous bending moment diagrams corresponding to pinned connection between the corners of bottom slab and the columns in this video:
2/ between edge/corner nodes of panels - see for instance this video (used the property that just after local mesh generation nodes on connections of panels are not merged):
As concerns 2 nodes with different coordinates LINK in SAP can be replaced in Robot by fictitious stiff member with appropriate type of release (elastic, non-linear, damper).
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
legar
How to model in Robot "gap elements" - see attached SAP video...
Pawel.Pulak
Autodesk Support
Autodesk Support
As concerns the second part or the video (uplift supports) they can be modeled as below:
undefined
As concerns the first part of the video (free link in one direction and with some gap in the opposite one, assigned to nodes with different coordinates) it can be modeled defining fictitious stiff members connecting these nodes with releases as below:
undefined
It may be additionally necessary to activate "Matrix update after each iteration" (Full Newton-Raphson) method to obtain convergence of some load cases and to activate DSC in Job Preferences.
Above I have defined such effects using Uplift properties in supports and Unidirectional and Gap in releases. Similar behavior may be obtained defining appropriate nonlinear behavior in Non-linear tab of support or releases.
Pawel Pulak
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
