Linear Releases on Freeform Panels from API
andrew.blackie6ZFFT
Message 1 of 1
andrew.blackie6ZFFT
I have created some custom freeform panel using the following workflow:
- Mesh in grasshopper
- Export nodes and finite elements to Robot
- Create panel from finite elements
Is there any way for me to apply linear releases to the panel edges, or is there a workaround? I have also tried exporting each element of the mesh as its own panels - this allows me to apply linear releases, but I see strange behaviour where moments still appear to be transferred across the perimeter nodes on elements where a single node in the tri intersects the perimeter.
Andrew
Replies (0)
