Based on your last picture ( one isolated slab) I built a more detailed model using compression only bars to simulate the contact between the pile cap slab/bar with the pre-fabricated slab 50cm thickness slab
I was expecting that the support would come from the inside nodes as the slab is "landed" over the pile cap slab.
But no . Due to the columms flexibility (almost 15 m height) , the pile caps rotate and support is given by the back nodes near the columms.
In a model with 2 slabs ,the center columm gets balanced and doesn´t rotate ,and as a consequence the 50cm slabs gets supported by the pile cap external edge nodes
Comparing a panel cut showing moment across the slab is easy to see the difference
Also panel maps showing bending moment map on global X direction(XZ plane) for both cases shows the difference
Of course if you can get more stable columms through bracing , stronger sections , the results would be different.
For the whole model ,The way it is now , inside columms will have small rotation on the top and the outer columms will rotate.
Sorry for the delay . Spent some time studying this case
both models attached
Rafael Medeiros
