Linear loads
Linear loads
Message 1 of 8
Linear loads
Is there a way to display a mesh indepedent linear load (kN/m) acting at the bottom and/or top of (f.ex) walls in Robot? I.e. from adjacent slabs etc. If the walls is simply supported, is there a way to display which load that acts on the wall for a manual control?
And in the case shown in the picture attached, which what is the maximum linear load (kN/m) at the bottom/top of the wall?
Replies (7)
Message 2 of 8
Rafacascudo
I guess you are asking about linear reactions instead of linear loads.
Linear reactions can be displayed through Results/diagrams on bars , Reactions tab. Choose average or integral value to be displayed
Rafael Medeiros
Message 3 of 8
Thanks. But if you have a simply supported wall, is there a way to display the linear load acting at the top of the wall? Almost like the "forces generated automatically" for bars?
Message 4 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
No, there isn't.
Artur Kosakowski
Message 5 of 8
Is there a way to use panel cuts, and how?
Message 6 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 7 of 8
Thank you. These results is mesh dependent? What is the correlation between the mesh and the results?
Message 8 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Yes, it is as any other type of results for panels.
See:
http://forums.autodesk.com/t5/robot-structural-analysis/finite-element-mesh-size/m-p/3752226
Artur Kosakowski
