kinematic constraints
Message 1 of 8
My model for some reason has been corrupted as my inspector dialog shows more nodes than i actually have. Please see image attached.
I tried to unmesh/remesh but the nodes are just doubled!! I also tried to run it but it gives me a kinmatic constraints error.
This seems to be a serious problem so please help me fix ASAP!
Kyp
Replies (7)
Message 2 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Open file in repair mode.
If it does not help please send us model.
Rafal Gaweda
Message 3 of 8
Were can i send it?
Message 4 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 5 of 8
Message 6 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Corrected file : http://we.tl/KscNDMXwon
Rafal Gaweda
Message 7 of 8
Rafal,
Thanks alot it works fine now but for future reference could you tell me how you fixed it? or what went wrong so i never repeat this?
Message 8 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
As I told you.
I opened it in repair mode, deleted unconnected nodes, turned off kinematic links, meshed the model and corrected the mesh manually. If you want you can unfreeze meshes remesh model and verify it to see where the panels are inaccurate. Then you can correct positions of these panels corners.
Rafal Gaweda
