Issues with mass and Stories
1161314
1161314
In Robot Structural Analysis 2022, there's an issue in dynamic analysis results if stories are created.
I've made 2 very simple models to show this.
In 1 model, i haven't created storie and get a mass of 28.297,12 kg with load to mass conversion and self weigth.
If stories are created, that value increases to 37.729,50 kg.
Simau
@1161314
For calculation model, select "shell" instead of "Slab-Rigid diaphragm"
M. Agayr
I've allready try that. I have the exact same model in RSA 2021 and the mass values do not change when i create stories.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @1161314
When generating stories in Robot 2022 open Advanced options and check off  "Create the main node forfloor diaphragmat the Gravity Center of the story projected onto the floor". Accept modifications in both dialogs.
This new option is activated by default in Robot 2022 and results in different (simplified) stories mass distribution for structures with diaphragms.
Krzysztof Wasik
okapawal
This issue has been resolved with Robot Structural Analysis Professional 2023 release.
Please find more in the Release Notes
Regards
Autodesk Robot Structural Analysis team
Waldemar Okapa
Software Quality Assurance & Testing Engineer
