Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Issue with Load Transfer in Multi-Level Load-Bearing Wall Modeling
6 REPLIES 6
antonio_rh
514 Views, 6 Replies
Hello everyone,
I’m currently facing a challenge in my structural model involving load-bearing walls across multiple levels. When I model the load transfer from the slab to the wall, it occurs uniformly as expected. However, when the load is transferred to the next lower level, it behaves as a point load rather than a uniform one. Additionally, when I model a wall on top of a slab, the wall behaves like a support.
Has anyone encountered a similar issue or can provide insight into why this might be happening?
Any advice or suggestions on how to resolve this would be greatly appreciated.
Thank you in advance!
Tags (2)
Labels (2)
6 REPLIES 6
Rafacascudo
in reply to: antonio_rh
Mesh size is probably too large. Forces  are transmited by the mesh nodes . If there are only the corner nodes ,than it will be concentrated.
Try to reduce the mesh size to get better results
Rafael Medeiros
antonio_rh
in reply to: Rafacascudo
Thank you for the suggestion. I did reduce the mesh size for the walls, which indeed created more nodes and more concentrated point loads. However, the issue persists when the wall is placed on top of the slab. The slab doesn't behave as expected; it seems to partially support the wall, causing the bending moments to reduce significantly—up to five times less than they should be.
I’m still facing issues with the accurate representation of wall behavior and load transfer. Any further advice on how to resolve this would be very helpful.
Rafacascudo
zip and attach the model  ,telling where the problem lies
Rafael Medeiros
antonio_rh
"The file 'wall test' includes the modeling of the walls and the load transfer from the second-level slab through the walls that discharge onto the first-level slab. When reviewing bending moments in Mxx, there is a reduction of moments in the central part due to the wall.
In the second model "wall test external loads", the loads from the wall's weight and the discharge from the second floor are simulated. In this case, higher values are reached, which differ from the wall modeling results."
Rafacascudo
That seems to be right as you have 2 strong walls supporting ,to some extent ,the wall that discharges some of its load on the slab beneath it. It is easy to see that effect when showing the principal wall forces graphically
If you want to discharge the whole wall load on the slab below , then you have some options to do it , described in my post on this thread
https://forums.autodesk.com/t5/robot-structural-analysis-forum/efficient-modelling-of-nonstructural-...
Also check another thread link inside my post on the thread above.
Orthotropic slab seems to be your best option
Rafael Medeiros
antonio_rh
Thank you so much for your solution! It worked perfectly, and the issue has been resolved. I appreciate your help and the time you took to guide me through this problem
