Issue with foundation beam design
Μηχανικος
Μηχανικος
Hi, When i try to import a series of foundation beams in the RC design module, the columns are not imported as supports to the foundation beams, therefore when i try to run the design i get an error that the support is too small for anchorage. how is this solved?
Screen Shot 2018-10-06 at 17.16.40.pngScreen Shot 2018-10-06 at 17.14.14.png
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Μηχανικος
Just enter the correct support widths:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
