Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Is this the correct way to copy load cases from excel to Robot?
yiviw97057
yiviw97057
Paste it into my load combinations - edit:
This is how it looks when I click on the "values" tab:
How can I change combination type? Am I doing something wrong when copying load cases from excel to Robot?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @yiviw97057
You can change it from Edit tab.
I would syggest turning on all table columns (right mouse button>table columns)  before copying from Robot to Excel. Then you can controll all columns in Excel before copying back to Robot.
Krzysztof Wasik
yiviw97057
Thank you, could I also ask if its possible to change the numbering of the load combinations outside of Load Types?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @yiviw97057
You can use Load table (Cases tab)
Check this Robot forum thread
https://forums.autodesk.com/t5/robot-structural-analysis-forum/load-combinations-combination-table-e...
Krzysztof Wasik
