Is load label important?
as picture above... I don't know if the "Load Label" important in which area of working in Robot?
some books said it is being used in the load combination dialogue ... but I see only the load Case name being used instead.
me1205377
hi,   it is not
it is just  a name you chose to assign to a certain load case   so you can differentiate between all load cases.
moustafa elgaar
mustafahesenow
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
  • Ok just see that it is used in the automatic combination section...thanks
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
In addition to better 'readability' as mentioned by @mustafahesenow (thank you) they are important for RC provided reinforcement modules.
Artur Kosakowski
