Inverted Tables
Inverted Tables
Inverted Tables
When I save the out put  from the printout composition into RTF file format, it gives a file with inverted tables !!
So, the first column is the last, and the last column is the first and so on.
Please check the images the screen shots !!
Note:
I am using Robot 2015
I am using Office 2013 to open the frt files.
Rafal.Gaweda
Autodesk Support
Autodesk Support
I guess related to some arabic system settings - "right to left"....?
Rafal Gaweda
I have solved the problem.
It is an office 2013 option.
