Internal error of the multi thread sparse solver
sre.thamilagaran
Observer Observer
sre.thamilagaran
Observer
Observer
I am currently running a rather large RC structure. I receive the "internal error of the multi thread sparse solver" when performing the analysis.  I encountered this issue only after I added few additional loads and internal walls to the structure at the roof level (ventilation shaft). Earlier I had only type3 instability, but the model still completed the analysis. Now I am encountering instability type 1 as well.  The instability is shown in the wall meshes only which was fine before updating the model. I tried remeshing the wall but still it did not work.
Thank you for your help.
Stephane.kapetanovic
hi @sre.thamilagaran
The internal error and the type 1 instabilities are surely linked. If the nodes are free, your new panels may not be linked with the previous ones. can you share your model on the forum?
Best regards
https://knowledge.autodesk.com/support/robot-structural-analysis-professional/troubleshooting/caas/s...
https://forums.autodesk.com/t5/robot-structural-analysis-forum/vba-excel-macro-for-any-object-geomet...
https://apps.autodesk.com/RSA/en/Detail/Index?id=964813656627065816&appLang=en&os=Win64
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
sre.thamilagaran
Observer
Observer
Hi @Stephane.kapetanovic,
Thank you for the help. Due to the confidentiality of the project, I am unable to share the model. But I will check the if the new panels are properly connected.
severin.wolff
at my model the issue "multi thread sparse solver" was also coming up. When I switched off the DSC-algorythm the application error No. 2809 came up.
What is the relation between them both?
Thank you!
hi @severin.wolff
Error list
https://help.autodesk.com/view/RSAPRO/2025/ENU/?guid=GUID-8E8ED7A4-9A55-4F1F-8771-7E1A9CEF73B2
you probably have instabilities
https://forums.autodesk.com/t5/robot-structural-analysis-forum/poblem-with-modal-analysis-error-2809...
Best Regards
