Interaction force
Interaction force
Ludwigswe
Message 1 of 8
Interaction force
Ludwigswe
Hello!
I have compatible nodes in my model. When I open the Interaction forces in the global system table and select result for compatible nodes I get zeros in almost every compatible nodes. The only nodes i get some values (not zeros) in is support nods.
How is the iteraction force calculated?
Regards!
Ludwig
Replies (7)
Message 2 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
We know that 😞
You can get forces there for rigid links made by RLINKs.
Rafal Gaweda
Message 3 of 8
Ludwigswe
Ok!
Is that a problem that you try to fix?
regards Ludwig
Message 4 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
We can say that
Rafal Gaweda
Message 5 of 8
Ludwigswe
I can not find anything about "Interaction force in globat system" in the Help,
do you have any information about it?
Message 6 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
No help
In short: forces "transferred" thru connection (interaction between nodes) presented in global coordinate system
Rafal Gaweda
Message 7 of 8
Ludwigswe
So interactionforces is based on diplacement of the node times some springcoeffecient (stiffnes)?
Message 8 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Yes
Rafal Gaweda
