Integration ROBOT to IDEA Statica Connection
david.valerioK6P4J
david.valerioK6P4J
I have installed Autodesk Robot 2021 and Idea StatiCa 20.1,
To install the add-in, I followed the procedure described in the following link:
https://www.ideastatica.com/support-center/robot-structural-analysis-bim-link-for-connection-design
After performing the procedure, I open the Robot 2021 but the option IDEA StatiCa in "Add-in" menu isn't available as expectable.
Thank you
DennisVDijk
Hi David,
Check add-in manager:
make sure the boxes are ticked.
Kind regards,
Dennis van Dijk
Structural engineer
www.ibureaunoordwolde.nl
david.valerioK6P4J
I haven't any boxes in the Add-in manager. Please see the attached images
david.valerioK6P4J
Steve.Quiros
Hi David
Did you manage to solve this? I am having the same problem. Thanks.
chams_chakroun
Community Visitor
Community Visitor
hi guys, did anyone figure out how to solve that yet?
pedro_m_dias
I solved it by adding manually the add-in. The problem was finding the right file. Mine was RobotConnectionAddin.dll located in "net 48" file inside the idea statica file.
