Instability type 3
Instability type 3
I´ve an "Instability type 3" error too and I´ve checked a several points that could cause this error (and that I find in the forum)", but I can´t get the solution. Can you help me please?
Is there somebody that can check my model?
I´m not finding small/anormal lenght bars, and I´m using "floor" contour (for example).
(I´m using 2021 version)
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi     @Anonymous
Refer to this "Can instability type 3 be ignored"
Krzysztof Wasik
I´ve seen and aparently it seems normal. The node displacements is only the thing i can check if it´s every thing
I´ve seen and aparently it seems normal. The node displacements is the only the thing i can check, if it´s every thing ok?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
So it seems that you can ignore instability type3
Krzysztof Wasik
