Instability Type 3
Instability Type 3
cainy7
Instability Type 3
cainy7
There has been numerous other posts regarding this issue, but I have watched the webinars and searched the forum undertaking all the tricks to try and identify the stability issue but I have been unsuccessful. I have fixed all releases but still get the error therefore I tried to find any small bars, the smallest of which is 100mm which I think is sufficient. I have tried using a different solver but still could not identify the problem. Anyone got any further suggestions or should this just be ignored as it does not seem to affect the response of the building i.e. the moment diagrams look correct and deflections are not overly excessive.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @cainy7
Move panel 1953 corner to node 359
Delete node 2096
Fixed file attached.
Rafal Gaweda
cainy7
Thanks Rafal,
Would you mind informing me how you spotted these errors so quickly?
I tried finding them for quite some time.
Kind regards
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @cainy7
1. Using this addin you get:
then after correcting panel corner position and changing solver to Automatic you do not need to delete mentioned before node.
Rafal Gaweda
ledinhchinh0409
Where is this addin? thank you
Romanich
Hi @ledinhchinh0409,
The list of all add-ins
https://forums.autodesk.com/t5/robot-structural-analysis-forum/useful-addins-for-robot-api/td-p/3899...
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
