Instability on the top of the tower
Dear users,
I am working on a special tower. I have to use for the columns totally rigid links (Ux,y,z/ Rx,y,z are blocked) and on the top of the external and internal tower parts (see on the figure) I have instabilities (Instability 3) with the nodes (Rx, Ry, Rz).
I have tried to close the tops with steel plates (as shells) with a fine mesh. Also I have tried to apply releases on the instable end of the columns and fix Rx, Ry, Rz, but the same intabilities happened.
I dont really understand why it happens, especially when I fix these degree of freedoms of the columns on the top end, any idea?
The only thing that helped to run it, if I applied a support, in which Rx, Ry, Rz were fixed. But I think it is not appropriate.. Or is it acceptable (because these top parts will be "closed" with steel plates).
Thanks in advance!
Replies (7)
I can provide the load in pm.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Mind that this type of instability may also be reported when you have large difference in the stiffness of the elements of a model for a perfectly stable structure. Try to apply a very small force or moment in the node and in the direction of the reported instability and check values of displacements and rotations there.
Artur Kosakowski
Thank you Artur your response!
This is a quite slender structure, but I thought there is no big difference in the stiffness of the elements. I added a moment (because the instability came from it) at a node (Rx was unstable and I added Mx=1kNm) .
But what should I see from the displacement results? To make sure that I can ignore the instabilities?
These were the results:
Node:134/2 Ux=-0 Uy=-2 Uz=-0 [mm] | Rx=0.006 Ry=-0.000 Rz=0.000 [rad]
Artur.Kosakowski
Autodesk Support
Autodesk Support
If there was a real lack of stability I'd expect RX to be much larger. I think that the instability is caused by having very short elements in the model.
undefined
Artur Kosakowski
However, so far I have merged these small elements and the instability is still the same. So it seems it was not 100% the reason. But in this case what else can be? I can send the model pm.
Artur.Kosakowski
Autodesk Support
Autodesk Support
If you want to play with your model try leave only the top part of your model and add supports at :cut" level. Calculate and see if you have any instability reported. If not, open the original model > cut it below the previous one and do the same. In this way you should be able to determine what causes the instability (you may also go from top to bottom if you like :-). )
Artur Kosakowski
I think now it isn't worth it, because this problem is relating to the solver. I have chaanged the solver to a multi-thread option and now, the place for the instability is just jumping within the structure. So I guess it relates to the stiffness differences because of the rigid links and somehow Robot has a problem to solve the matrices.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
