Instability of Node in one point, Why not in others? How to solve?
See attached photo.
Found Instability of Node in one point in X direction.
But similar node are also in the model with similar member & releases.
Why this node is only instable, why not others?
If other nodes are also instable then what should I do to solve it?
Please help me. Thanks in Advance.
teixeiranh
Your instability is a type 3 instability. That happens when the program finds 2 elements in the stiffness matrix main diagonal with a enormous difference of values. If you have good results, then I think that you don't need to hurry about that.
“The most powerful force on the universe is compound interest.”
Subscribe me on Youtube:
https://www.youtube.com/channel/UC6G8OOp318Z1MFzJj5T8uWw
