instability node (type 3)
Hi everyone,
How can I fix the warning "instability node (type 3) ?.
I model a building with 6 stories. From the roof to the ground floor. When I model the roof to the 3rd floor, everything is ok, no warning & errors. Then, when I model the 2nd floor, there no have any warning & errors in meshing generation but I got a warning message: " instability node (type 3) and that node on level 5, which no have any warning before.
So that, how can I fix it ?. And how to know the warning message not more affect to the model ?.
Thank you so much!
Rafal.Gaweda
Autodesk Support
Autodesk Support
File please.
Rafal Gaweda
Hi Rafa,
I send you two file.
The model L3 to Roof is no any warning & errors
The model Roof to L2 is have only 1 instability node ( type 3 ).
Thanks for your help.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Set model generation tolerance as User Defined = 1mm
Generate model
Freeze panels
Run calculations
Fixed model attached
Rafal Gaweda
