Instability issue
Instability issue
Instability issue
the node number 26 belongs to three bars: the column 13 and the beams 230 and 231. In the same node the beam 231 has a release about y (and z) axis while the beam 230 and the column 13 have no releases in that node; I expect no instability in the beam 230 but instead it happens.
The same problem for the beam 58 due to the release in the beam 59 in the node 74 (Robot gives me a warning about instability in the node 74 about y direction).
What should I do to have cantilever beams on one side and released beams on the other side?
Thank you!
Rafal.Gaweda
Autodesk Support
Autodesk Support
File please.
Rafal Gaweda
I have a problem when I send the file: the file ".rtd" is too big and the zipped file ".zip" or ".rar" gives this error: "The contents of the attachment doesn't match its file type."
What can I do?
Giorgio
Rafal.Gaweda
Autodesk Support
Autodesk Support
