Instability in shell model
MRCH94D9W
MRCH94D9W
I'm experiencing some stability issues which I can't figure out.
I have some shell elements supported by two columns with fixed supports in the bottom, (See Figure 1).
As the model is right now, there are no instability issues. However, I want to put in an element on which I can apply some load between the two columns. This element is connected by 4 points to the columns and 1 point to the roof.
When I attach a beam element to the column I get instability in the shell elements, (See Figure 2).
My mesh geometry is healthy and no incoherence is reported, so I'm at a loss here.
I have attached the model and I hope you will take a look at it .
Thank you very much.
Bonus question:
I have tried to use the "Reduction of forces above columns and wall" feature under the "Maps > Parameters", but it would seem this feature only works with vertical frame elements connected perfectly perpendicular to the shell element. Is this really true?
Initially I tried to use this feature, but I ended up connecting the frame and shell elements by rigid links, which I suspect is the root of my instability problem.
Rafacascudo
No need to worry .This instability type 3 warning can be ignored as your node displacements are normal for that type/size of structure. Search the forum for similar posts and check webinar 16 about this on Build your Robot Structural Analysis IQ - YouTube
For the " reduction of forces" use rigid links around the columm section perimeter .
And yes the Rlinks are the root of the instability warning type 3 , which can be caused by a large difference in stiffness between members
Rafael Medeiros
