Instability caused by having cladding in a model
e2009355
e2009355
Dear all,
I'm modelling steel building for car parking. the instability (type 3) has appeared during calculation in 1st order analysis and even in 2nd order analysis (I use Direct Analysis Method). I try to find solution in your webinar (Video: Instability), but i cannot fixed it.
How can i do or i ignore theses instability?
Thanks very much!
@e2009355 Artur Kosakowski edited the topic for better findability
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @e2009355
My assumption is that cladding divide bar elements into very small calculation elements which causes large difference in values of elements of the stiffness matrix as when you delete them no instability is reported.
Artur Kosakowski
e2009355
Thanks sir, but how could i do? i try to change cladding to panel slab, but it doesn't work. It woks when i put load on beam (kn/m) and transfer to girder. So what your recommendation, I should use load panel (kn/m2) or load on beam (kn/m) then transfer to girder?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @e2009355
I'd ignore the warning and carefully check the obtained results. You may also apply init force/moment on the direction and the location of the reported instability. You mat find the relevant information in the 16th Robot webinar on the instability subject.
Artur Kosakowski
e2009355
Thank you very much, sir.
