- Mute
- Permalink
- Report
I have a 3D steel frame model (version 2020)with gravity load applied ( no lateral load applied). There is no bracing member in the model because I assume the lateral load will be taken by reinforced masonry walls around the perimeter. Here is my the problem/questions regarding the attached models:
- Initially, I released all the beams as pinned-pinned to sizing the members, you can see there are lots of instability warnings in Model "Steel Frame_v20(All Released)" and huge deformations
- Then I tried to change back some released beams back to N/A, around the nodes which were warned had instability; and end up with the model "Steel Frame_v20(Not All Released)" WITHOUT ANY WARNING.
My questions(please see the attached models):
1. Was it a correct way I tried to eliminate the warnings?
2. I changed some beams as non-released, so there will be some negative moment at end of the beam and the positive moment in the mid-span would be smaller than that when the beam is pinned-pinned. Will this influence the beam size?
3. In the model "Steel Frame_v20(Not All Released)", the frame has side-sway under only gravity load. Is there something wrong or is it normal because of the unbalanced gravity loads?
4. If the side-sway is normal and due to unbalanced gravity load, why there is no side-sway in the model "2D FREAM" which I applied unbalanced load for testing purpose?
Appreciate your response
