Incorrect definition of the local axis of the panel
faisal.aaouatif
faisal.aaouatif
Can not understand why this error occurs only for the panel 963 ( see attachement and model ) and not for others ( slabs ) even they have the same caracteristics.
thank you for help.
Artur.Kosakowski
Autodesk Support
Autodesk Support
It seems that you accidentally defined the local X axis of this pabel as being perpendicular to it. It is enough to redefine it as shown below:
Artur Kosakowski
faisal.aaouatif
Hi Artur ,
ive intentionally defined local axis of panels Smiley Happy
even the local axis of the panel 963 is oriented to the direction 1 0 0  as seen on the attachement sent the problem hase been raised.... , but by redefining the local axis, a second time, atthe same direction ( 1 0 0 ) , the problem hase been resolved (it eems that the information hase not been updated at the first time ... ).
Thank you very much.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Mind that Robot is not capable of displaying correctly the coordinate system of the panel when its local X axis is defined as perpendicular to the panel. In such cases the display will be apparently correct with the warring displayed during the verification.
Artur Kosakowski
LuisMCosta
I'm having this problem as well. The message of incorrect local axe definition appears.
I'm not sure if it's related, but on the right, finite elements are created.
Can you guys help me?
Please find the model attached.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
