Incorrect data Error 5000
puisan_wong
puisan_wong
Hi, during the calculation of a structural model, the error message keep pop-out "Incorrect data Error 5000"
Is there any way of overpass this error ?
Thank you.
Edward
Stephane.kapetanovic
Hi @puisan_wong
See https://forums.autodesk.com/t5/robot-structural-analysis-forum/error-no-5000/m-p/11392324
Best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
puisan_wong
Thanks @Stephane.kapetanovic
I've tried to restart Robot and changing the mesh option. But the error is still popping out.
Is there any other way to resolve it ?
Thank you.
Edward
Hi @puisan_wong
Try backing up your file under a different name and restart it in Safe Mode.
Best regards
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @puisan_wong
Roof claddings  5574 6487  are not flat and loads are not distributed from them.
After removing claddings  5574 6487  model can be calculated.
Divide claddings  5574 6487  in bigger number of smaller (flat) claddings or correct roof geometry to obtain flat surfaces.
Krzysztof Wasik
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @puisan_wong
Hi @puisan_wong
Regardless problem with claddings  5574 6487
It seems that you have not preciselly defined model and you are trying to correct it by model tolerance increased to 10mm. It probably generates incorrect (very small) calculation members which cannot be calculated using elasto- plastic analysis.
I would suggest correcting model geometry and decreasing model tolerance.
After some experiments with tolerance I was able to calculate shared model version.
Krzysztof Wasik
Hi @puisan_wong
in addition to the message from @Krzysztof_Wasik  see after a report to show where the inconsistencies (0 to 10mm) occurred
Best Regards
report deleted
