Importing .str file (from STAAD) suggetsions: Finite Elements --> Panels
Dear Community
I have been trying to import a relatively complex plates model from STAAD. It is a steel plated structure with several decks, and vertical plates with several orientations.
In order to do this, I understand a .str file is created by Robot SA and then a .rtd file.
During this process, the model is imported in Robot SA comprised of 'Finite Elements' with no panels. This worked with no problems.
However, my understanding is that this method does not capitalise on the advantages of Robot SA which is to use panels with adjustable meshes and to view the results 'maps'.
Ideally I would like the Finite Elements to be assigned into panels with one panel on each level on each orientation.
I have already tried renumbering the plates on STAAD so the numbers are sequential but there are over 40 groups each of which has 20+ sets of plates, which becomes very laborious to enter with Geometry--> Panels-->Surface elements (FE) list.
Is there a way that Finite Element to Panels conversion can be further automated?
Any thoughts would be much appreciated. I am unfortunately unable to upload the model.
Kind Regards
Ben
