Import from SAP2000
Import from SAP2000
Import from SAP2000
     When I import the s2k file of SAP2000 (V18)  into the shell design module of RSA(Open Project),  the error message occure. I want to ask which edition and message  of SAP2000 s2k file can be transfer to  the shell design module of RSA. Can all the imformation (Node,ELEMENT,Load, Load combiantion)  can be imported from SAP2000 ? Thank you.
ERROR
Rafal.Gaweda
Autodesk Support
Autodesk Support
Unfortunately SAP file syntax wit "tables" is not supported
Rafal Gaweda
Can you provide a valid and accepted  s2k file of sap2000. I want to learn the specific format accepted by RSA. Thank you.
Rafal.Gaweda
Autodesk Support
Autodesk Support
I do not have such old format file.
Just open s2k file in Notepad. If you see "TABLE: ....." in it , it mean it is too new.
Rafal Gaweda
I am surprised that RAS don't update to support the lastest sap2000 file (s2k format).
