Import foundation with anchor bolts into Robot
Message 1 of 22
To save modeling effort, I'm attempting to import a foundation from AutoCAD 2015 into Robot 2015. The foundation consists of 16ft x 16ft x 5.5ft concrete mat with a 20 point polar array which represents the anchor bolt locations for a tank that will be mounted on top of the foundation. When I attempt to import this into Robot only the array appears and the box representing the foundation. Is there a particular setting that will allow the importation of both? I'm hoping I can import them and then apply material properites.
Replies (21)
Message 21 of 22
Yes but that creates the scaling issue I mentioned in post 11. The fix you show in post 12 does not adjust the scale of the imported bars and nodes.
Message 22 of 22
Rafal.Gaweda
Autodesk Support
Autodesk Support
Scaling of model can be done also by Edit \ Edit \ Scale
Example of planar support for solid NOT made by imprting sat object:
Rafal Gaweda
