Ignore Uplift
Ignore Uplift
Ignore Uplift
How can I ignore uplift forces in spread footing design.
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm not sure if I understand you correctly - do you mean allow for uplift?
Artur Kosakowski
I mean disregard the uplift forces, I don't want the forces uplift in spread footing design
Artur.Kosakowski
Autodesk Support
Autodesk Support
You may try to exclude combinations with such effect from being exported to the RC Design module.
Artur Kosakowski
saclovitzky
probably what he meant is "pure compression only".
