Announcements
ifc and etabs to robot
TSOFA
TSOFA
hi I need to convert these model to robot 2020. When I try to open the ifc, robot can not open it (says something about dos)
the link has the ifc and the etabs to revit file
https://we.tl/t-mTR1fZf4Ib
could anybody help? thanks!!!
Replies (9)
Have you tried using any of the Geometry Gym tools??
https://geometrygym.wordpress.com/
https://geometrygym.wordpress.com/downloads-windows/
If you download the ggRhinoRobot plug-in you should be able to create a robot structural analysis model from an ifc file.
Cheers
Nathan
First testing it works pretty well but could improve with some problem elements. If you are looking to go from Etabs to Robot Geometry Gym also has an enhance ifc export from Etabs which should provide better ifc transfer results.
TSOFA
I downloaded the file that you mentioned and run it, but there was no change to Robot software. The other thing is that I open Etabs I save the model to IFC and then even though Robot can open an IFC file, it doesn't open the one that etabs created. Why? which version of ROBOT do you use? I use 2020. Finally, when ETABS saves a model as IFC, loads are not transferred?
Apologies, I did not explain the tool. That is a plug-in for Rhino/Grasshopper which does the conversion through the Robot API, Downloading and installing it will not change the Robot Interface. If you do not use rhino/grasshopper we do have standalone programs which can do the same process without Rhino/Grasshopper. if you would like to learn more get in contact support@geometrygym.com.
I can't help you with why standard Etabs to Robot (standard import) is not working but I would suspect that either Etabs does not support extraction of loads or robot does not support the import of loads. We have our own IFC conversion from Etabs which includes a lot more structural concepts.
P.S I  work for GeometryGym
Hi @Anonymous
I am also interested in importing IFC into Robot. I tried ggRobot tools and I am able to use the Robot solver inside GH and also bake the model into Robot (file SimpleBeamRobotggBake.rtd). Then I used the ggIFC component to create an IFC file (SimpleBeamRobotggIFC.ifc). The IFC file contains all the information created in GH (section prop, support, loads) but when importing it into Robot it loses the majority of the information (see file SimpleBeamRobotFromIFC.rtd).
Any idea on why this happens? Does anybody have an example of an IFC file that can be fully read by Robot? - I would like to emphasise that I am only interested in transferring IFC (which is open source) into Robot. Zip file attached.
Many thanks!
Leonel
@Anonymous It is likely because the out-of-the-box Robot Import IFC functions may not support importing of loads and advanced IfcStructuralAnalysis concepts. This is why we provide enhanced tools which convert all types of IFC files.
https://technical.geometrygym.com/rhino-grasshopper/structuralanalysis/geometry-gym-model/structural-model/converting-analysis-models/structural-analysis-detection
We do have a component in ggRobot plug-in called ggRobotConvertIFC which should pull in information from an ifc and then bake to Robot through the API. These videos should help although they are done using the SAP components. Robot is the same process.
https://www.youtube.com/watch?v=MTMfbeRU_jM&list=PLajD1zxzDkUd9jXfKgeZ4A9irhNI7o63s
hi @Anonymous ,
That makes sense, thanks for having a look. At the moment I am baking directly from GH to Robot using the ggRobotbake component which works perfectly fine. What I am looking for is to create a general IFC file that not only contains the analytical model but also other IFC classes and properties (e.g. building the IFC using the more general GGIFC plug-in).
There was an IFC to Robot converter on GG website some time ago, but it is not available anymore (https://www.youtube.com/watch?v=j6KLIqK0pDI&ab_channel=GeometryGym).  A converter like that would help to read the analytical information from a general IFC and then import the information to a relevant FE software, in this case, Robot but it could be any.
Much appreciated,
Leonel
These stand-alone installers are still available and can be provided...Although we were trying to add a function within Robot instead of using a stand-alone executable.  We can provide similar things for most of the structural analysis software we support.
Within our ggIFC plug-in for grasshopper, you can create a 'general IFC' (as you call it) model with an associated IFCStructuralAnalysis Model view as well.  Our tools can be used to interpret a structural analysis model from a 'general IFC file'.
If you want to discuss further maybe we should set-up a call. if you contact support@geometrygym.com.
Thanks @Anonymous ,
The function within Robot to read IFC files (and I imagine other FE software files) sounds like a good idea.  I will send you an email shortly.
Kind regards,
Leonel
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
