Idealised Pile Cap - Support conditions
I have modelled in a simplified rectangular pile cap as shown, however I cannot seem to get the mesh to create nodes around the perimeter of the pile.
Also, i would also like to give the node support a horizontal restraint in the Y plane, but cannot see option? And for analysis, isoline map does not seem to be analysing, although slefweight loads are decomposing.
Many thanks
Rafacascudo
post a a larger picture please!!!!
Rafael Medeiros
As requested !
AhmedZA
 My suggestions
delete meshing
draw circle (two arc ) with the same diameter of pile then run mesh again and delete circle  or try use Delaunay method and define a denser mesh
i'm not sure if i understand you correctly do you mean something as shown below
