Hydrodynamics
Hydrodynamics
mathias_peron
Message 1 of 22
Hydrodynamics
mathias_peron
Hi everyone,
As I'm modelling a water tower in a seismical region I neet to take into account the ovement of water during the seismic analysis.
I have found very interesting topics on the forum and very interesting articles before to post here.
I would like to use the Housner's model for elevated tank and I'm following what have been done before here: http://forums.autodesk.com/t5/robot-structural-analysis-forum/how-can-model-hydrodynamic-pressure-on...
I still have few questions:
- When setting the convective mass (mass on node in Robot), I understand that it needs to be only in X and in Y. But when setting the impulsive mass (that is the mass that doesn't move), don't we need to set it in Z as well?
- Can the impulsive mass be set exactly like the convective mass but with bars with infinite stiffness?
- Do I need to check the box "Apply to all cases" when setting the masses?
Thank you in advane and have a nice day!
Mathias.
Replies (21)
Message 21 of 22
Artur.Kosakowski
Autodesk Support
Autodesk Support
You don't define forces of inertia for a modal case. For a modal case you can define added masses (which influence eigenfrequencies and shapes of modes) but you can apply body forces to these added masses for static analysis.
Artur Kosakowski
Message 22 of 22
mathias_peron
Thank you.
