Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
How to View all the wall support Forces between wall and slab
Hello
How to View all the wall support Forces between wall and slab , the First photo from Robot ( i need to know the reaction from the walls at The edges of the roof ),  photos 2 and 3 are the reaction from the walls at The edges of the roof from another Program . I need the view the results just like photo 2 and 3 . 112233een wall and slab
Rafacascudo
Not directly , but you can have the vertical reactions through panel cuts.
I built a similar model and applied 4 consecutive panel cuts 2cm below top of the wall to be able to display the panel reduced forces. Results are very similar compared  to the wall bottom total reaction.
Other than that , you should improve your meshes .As they are in your picture, They show that you have geometry imprecision on your model. Heavy node concentrations, or the contrary, large spaces between nodes are never a good sign for good geometry/meshes.
You should watch the official autodesk webinars(1 and 2) about good mesh practices on Build your Robot Structural Analysis IQ - YouTube
example model attached
Rafael Medeiros
thanks 🙂
