How to switch back to plan view from 3D view in Robot Structural ?
yesterday55555
Message 1 of 9
yesterday55555
Hello everyone. How can I get Plan view like this back from 3D view ?
Replies (8)
Message 2 of 9
Romanich
Xin chào @yesterday55555,
Just press this tab :
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 3 of 9
yesterday55555
No. That is not the things I want to.
I means in the tab Plan view but shows 3D views. I could not get the plan back to defaut
Message 4 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @yesterday55555
Please attach the model and the corresponding screen capture when you have such situation again.  In general the change of the structure type from a Building to a Shell and back to a Building should solve it.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 5 of 9
yesterday55555
Here is the problem, bro. I am sorry  I do not have the file now. But when I open the file others computer, there is not problem. I think somethings the issue is in my setting computer with robot structural system.
That problem is not showing when I open new file., but the file I have been modeling.
I have tried to make the file to the setting defaut, but I could not do that.
Message 6 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @yesterday55555
Actually you are in the Plan (2D XY) view which is indicated by the description of the global axes and the red rectangle which indicates the fixed plane position. I can't tell why you can't see the Plan view (perhaps it will be just enough to close Robot and open it again as it seems to be just a display issue) but it is such.
Artur Kosakowski
Message 7 of 9
yesterday55555
ok. I do not know why it has got the problem. But It maybe need to closed then open to fix it.
Message 8 of 9
benW2Q54
I've literally just started using robot and I can't even find the icons on the top left side of the screen with view and plan. Tried restarting it several times and still no luck. I mean I created grids and storeys but can't actually go to the plan view of each storey.
Message 9 of 9
yesterday55555
@benW2Q54 you must choose the buliding design when I started new project
