How to put beam rebar into more than one layer by typical reinforcement?
Hi Everyone,
I have a question related Beam Design in Robot. I want to put main reinforcement into two different layers by using typical reinforcement option. I need your recommendation on the beam analysis with 2 layer.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
The typical reinforcement is intended to generate single reinforcement layer reinforcement pattern but after generation reinforcement in the beam with this tool you can select and copy the reinforcement bars to the second layer.
Artur Kosakowski
Dear Mr.@Artur.Kosakowski,
Thanks lots for your quick response!
I'm able to do the beam analysis with 2 layers of rebar now.
Good luck!
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I'm glad you managed to make the reinforcement to look as you wanted it to be Smiley Happy
Artur Kosakowski
