How to model purlin
How to model purlin
j_garnierYCZEH
How to model purlin
j_garnierYCZEH
Hello everyone,
I would like to model a purling with a canteliver at one of its end. (see picture below). I have applied a gamma angle of 1,68° to the purling and an offset of 250 mm. The beam of which the purlin sits, has also an offset (if that is relevant in any way).
What should the release between the purling and its support be?
Moreover, I am gettin an instability type 3 at the end of one of the purlin (and if I delete the cantilever part, I get the same instability to the next purlin and so on)
How to get rid of this instability?
Can't seem to be able to attach the model.
Thanks a lot in advance,
Jules
Stephane.kapetanovic
HI @j_garnierYCZEH
You can use compatible nodes
https://help.autodesk.com/view/RSAPRO/2023/ENU/?guid=GUID-827814C0-A254-4361-B199-DCC6D996817B
Best Regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
